Aded
Hi all, am looking at changing my ATF oil and filter myself, but my problem his how to jack all the four wheel up to level.Hope it will be easy.my car is w204 c180 2012.
Any advice well come.
Buy a 3 ton Jack so you can lift the front by the front jacking pad in the middle under the engine and under the rear diff to lift the rear .Hi all, am looking at changing my ATF oil and filter myself, but my problem his how to jack all the four wheel up to level.Hope it will be easy.my car is w204 c180 2012.
Or take it to an Indy and pay them circa £350 for the pleasure of them doing it for youOr , drive onto wheel ramps at the front and then reverse on to the rear wheel ramps
I can’t do that buddyOr take it to an Indy and pay them circa £350 for the pleasure of them doing it for you
You will also need a sump adapter to get the oil in and a fitted plumbing tap just below the adapter to turn the oil off .Hi Pete, Aldi pump to pump the transmission oil.
