flango
Hardcore MB Enthusiast
I had a compressor in the car but the tyres side wall was damaged as it was run on flat and it would no longer hold air. I'm not worried about the tyre as ATS have already stated there was no fault with the tyre and that it was corrosion.
I don't believe the second fitter performed work above reasonable steps the standard usually applied to prepping a rim. First of all he didn't grind it he used a wire brush for about five minutes.
Secondly they have stated that in law they have to take reasonable steps to ensure a good seal. Now if all rims where equal then we could define the amount of work necessary but as all wheels are different and in different states of repair the amount amount of work necessary must be guaged by the fitter and where it is deem to be to great or beyond there ability to fix then they can refuse to fit the tyre.
They didn't refuse and they didn't warm me of a potential problem. They are basing their case on the fact that the wheel was to corroded to provide a good seal.
So why did the first guy fit the tyre? why did he not warn me? why did he not use the better sealant? Why was there sufficent rust left on the rim to cause the tyre to fully deflate within such a short period of time?
I can only conclude he didn't think the wheel was a problem or he didn't prep it correctly either way he was at fault.
I still believe your problem was caused by the fitter in the first place, wire brushing a rim and putting sealant on is common place he obviously did not do this, resulting in the unit replaced on the car was not fit for purpose end of story.
This link gives you the ATS Head Office details http://www.transportweb.com/directory/443/14515/
Call them ask to speak to the sales director, if you can't get to him ask for his name and tell them you require this to serve a summons on the company. I guarantee they will be back in touch and will come to the party. ATS are a wholly owned subsiduary of Michelin and even if you do have to get recompense through the courts they wont fight it, it's just too expensive to hire lawyers to defend a small claim against a big company, good luck
