audio 20 radio removal
robk
im trying to remove the audio 20 radio from my 2003 w211 mercedes.its also got the cd player built under .ive looked everyware for a step by step guide but cant see one anyware .any help please
Diesel Benz
Europe
222.132 & 221.122 & 213.050 & 906.633
I thought I had seen a guide with photos but could not find any quickly.
- remove the cover around the gear shift lever by lifting from the front first, move the gear shift lever when necessary.
- pull ashtray out (two clips at the front, low at each side), detach cables.
- remove wiring harness and fibre from the bottom of the CD changer
- unscrew the two bolts at each side (facing directly towards you) of the changer or stowage compartment. Remove the changer/stowage compartment.
- unscrew the two bolts at each side of the head unit. These are at the bottom/front of the HU, facing directly upwards. Unsrew all the way.
- the head unit is released, you can just pull it off.
OP
OP
R
robk
thanks for a quick reply .my job for toomoorow
