zishan03
Hi Guys,
I have a problem with the audio system in my car. The whole thing is 100% factory fitted now. The problem is that, when it rains the "reset fuse" in the engine bay for the cd player keeps tripping out which causes the radio to carry on playing but the controls become unresponsive from the actual stereo and from the steering wheel. At this point on the display in the speedo it says "- - - -" instead of the name of the radio station or the cd track number. Also at this point when I turn the car off and pull out the key the radio continues playing, even when i close the door. Eventually it stops playing but the display on the headunit itself still stays stuck on whatever it said when the problem started. To make things normal again I have to simply unplug the 10 amp fuse in the fusebox in the bonnet and plug it back in. I'm guessing that the rain water is getting somewhere and tripping it out so does that meaan an earth wire is loose or something?
Thanks in advance guys,
Zishan
Zishan
