auto box slippage. 300e
dave1964
hi all, just joined and was wondering if anyone has a reason for my 1988 4sp auto box slips when changing gear, usually when cold. it's just as if it loses all gears just for a second and the engine revs up. any thoughts?!?! :)
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
Has it ever had an oil change on the gearbox? What mileage is it?
OP
OP
D
dave1964
thanks for getting back to me to quickly. mileage unknown but all controls are VERY clean (i.e. under 100k). I havn't changed the oil yet but it didn't seem to help too much on my last merc, a 190e 2.0 with similar probs.
Dieselman
Banned
Peugeot 403 Convertible
Low on ATF.
Check the level.
ROB99M
Slipping gearbox
If not low on oil due to a leak then clutch piston seals need replacing do it before it burns the clutch out
jenz
UK
Mercedes 300TE 24v
Reverse Slipping
Hi
I have a 300TE24v and about 3 months or so I have noticed that my reverse gear slips. However, it works fine in the morning - yes like you mentioned it has high revs. The problems starts when the temperature reaches above 80 degrees or after 10 minutes of driving - the reverse gear slips. The entire car wobbles but doesn't move and if on a hil it will just roll down it.
I have recently had the gearbox and filter changed about 4 days ago and I am still experiencing the same problem. During this work the oil was drained from the gearbox and about 4.5 litres of ATF oil added from the 5 litres.
Does anyone know what fixes I could try?
Regards
Jenz
jenz
UK
Mercedes 300TE 24v
Lucas Oil Transmission Fix
Hello,
Has anyone heard or used a product called Lucasoil Transmission Fix?
See url: http://www.lucasoil.com/testimonials/1991,1.html
I am tempted to use it for the slipping reverse that I am getting.
Please, please, please let me know if this is real or a hoax.
Regards
Jenz
stwat
Sheffield
1989 W126 300 SE
Hmmm, id be a bit worried about putting any kind of adative in the auto box tbh. but thats just my view mate.
Stu
sportyreptile
South Wales
96 W210 E36 AMG
Either needs an oil change in the box or could possibly be the Air Mass Meter thingy playing up.
This can cause funny problems so I'm told i.e - gearbox does select a gear because the ECU doesn't think the engine is producing enough torque.
Does that make sense or have I confused myself? A MB specialist should be able to look at the ECU error logs to determine whats happening.
