Glenn Smith
- Mar 7, 2006
- 2000 c230k estate
FINALLY GOT ROUND TO CHANGING THE OIL THE GEARBOX THIS MORNING, 722.6 TYPE TRANSMISSION, HAVE ENCOUNTERED TWO UNEXPECTED PROBLEMS, ONE THERE IS NO DRAIN PLUG ON THE TORQUE CONVERTER, SO I'LL HAVE TO RUN THE CAR AND CHANGE AGAIN, SECOND ONE SCREW SNAPPED OFF ON THE SUMP RETAINING LUG DUE TO CORROSION ON THE SCREW IN THE ALLY LUG EVETUALLY MANAGED TO FREE THE LUG WITH SOME GENTLE PURSUASION AND THE REST OF THE SCREW CAME OUT EASILY ALL BACK TOGETHER NOW WITH SOME DECENT QUALITY SCREWS AND COPPER GREASE WHERE THE BOLTS GO THROUGH THE LUGS ALSO PUT A SMALL DROP OF LOCTITE ON TO PREVENT LOOSENING AS THE ORIGINALS LOOKED LIKE THEY HAD SOME THREAD LOCKING COMPOUND ON. i'VE ALSO FITTED A NEW CRANK PULLEY SEAL AS IT LOOKED LIKE IT WAS LEAKING, THE RETAINING BOLT WAS F TIGHT, NOW I'M WAITING FOR THE SEAL TO "SET" AS IT IS A PTFE TYPE WHICH REQUIRES 4HRS AFTER FITTING BEFORE RUNNING ENGINE THIS TYPE IF SEAL ALSO IS FITTED DRY! tHERE WAS NO WEAR ONTHE PULLEY TO SPEAK OF. jUST THOUGHT I'D SHARE MY EXPERIENCE WHILST I'M WAITING.
