turnipsontoast
- Oct 27, 2014
- vito dualiner
had a couple of issues with srs warning light on my 111 cdi vito w639 and thought I'd have a go using an autoaid diagnostic kit I bought off ebay last month from Germany great bit of kit , hadn't used one before , followed basic instructions and worked no bother first time , cleared srs ecu dtc which were passenger seat plugs , also showed up another fault which states it may be supply overvoltage to aircon unit or either a sticking passenger window switch , cleared these codes at same , the info i'm after is the 4 digit fault codes , preceeding the brief description of fault where can I refer for clarification as sometimes there is only a 4 digit code and then permanent displayed after it with no explanation ?
cheers
Mike
cheers
Mike
