Autobox shift speeds
Trickythemerc
South Manchester
CLK 220 CDI Sport 2009
Hi guys, Newbie here just bought a very nice 220 CDI CLK and love the car. It does seem to want to hang on to 4th gear ? or maybe it's just me ? Under normal conditions and using sensible throttle it changes into 5th at just over 40 MPH is this normal ? With 74k and no mention of a box service having been done I am going to order the bits and do it as a matter of course. Any tips and hints will be most appreciated.
Tricky:thumb:
Which mode are you running in? C or S or is it the same in both?
Did you get this sorted tricky?
I found resetting the transmission ECU allowed the car to adapt to my driving style, and began upshifting at lower RPM's.
^as above. I believe gearbox adaptations can be reset via star and some OBD scanners.
