John Jones Jr
- Mar 23, 2013
- Location
- London & Dublin
- Mazda MX5 10AE, W201 2.5-16, W202 230K Sport man, Honda Accord & Suzuki 'Ricer'.
There were some other qualities about the car on winter tyres that were less desirable, true.
And the car’s traction control also become neurotic, killing the power at the merest whiff of throttle, even on bone dry roads.
. But from a safety POV they are worse than standard tyres when there isn't snow/ice, and of course traffic speeds are higher.
...But from a safety POV they are worse than standard tyres when there isn't snow/ice,
at BMW’s insistence the car was fitted with a set of Michelin Alpin winter tyres. And when it came back I was stunned by how different it felt to drive; how much more comfortably it rode, how much sweeter it steered, how less fidgety it felt on badly surfaced roads, and how much more grip it had everywhere in the wet.
The whole car felt as if it had been unlocked somehow, and there was also an amusing little sticker that had appeared in the top right-hand side of the windscreen, warning me not to drive above 149mph. As if BMW GB was saying: ‘Because we know what sort of larks you normally get up to in our 1M…’
There were some other qualities about the car on winter tyres that were less desirable, true. I noticed, for instance, that the speedo had become wildly ambitious; at a true 70mph it was reading almost 80mph, which meant the fuel range indicator was similarly off-piste. And the car’s traction control also become neurotic, killing the power at the merest whiff of throttle, even on bone dry roads.
OK I'll bite
And the car’s traction control also became neurotic, killing the power at the merest whiff of throttle, even on bone dry roads
That confirms a significant reduction in grip when it's not snowy/icy (presumably "even" on dry roads means it also happened when they were wet). The winter tyre test last year where braking distances were objectively measured found the same thing.
So in summary ... they are a great convenience in that you won't get stuck if it snows. But from a safety POV they are worse than standard tyres when there isn't snow/ice, and of course traffic speeds are higher. IMO they are a no-brainer if you live in an area where there's consistent snow in winter (Germany etc.), but that doesn't apply to much (most?) of the UK.
I would beg to differ slightly in that you are assuming the traction control kicking in signifies a big reduction in grip whereas what in fact is being measured is a significant variation in tyre rotational speed due to the greater flexibility of the deeper tyre tread.
I thought the article raised a few questions.
It sounds like BMW dropped a ball and changed the rolling radius of the wheels significantly - this smaller radius and therefore gearing would probably explain why it was easier to bring on the traction control light as opposed to being caused by lack of grip which was more than dismissed earlier in the article.
It's the same reason you get people saying they've never had any problem driving their MB in winter, when other people can't move on the slightest incline - in winter, some summer tyres perform better than others.
It's also true that people generalise about 'winter'. I'm going to stick my neck out and say that people who say they've never had any problems driving their MB in winter are the same folk who have never actually driven in snow.
Another generalisation?
Also quite inaccurate as I have driven my C320 in heavy snow in and around the New Forest and local roads here that had not been treated. I have never lost control or had a problem but in all cases I drove very carefully and slowly but I got home each time
