alantemperton
- Jun 3, 2007
My CLK430 2001 AMG (105,000 miles, regularly serviced) has suddenly devloped drive problems. It all started with slight hesitation when starting from stationary .... and when slowing down for a junction or roundabout and then accelerating away the car surged forward as though someone hit you up the rear. On first starting in the morning it then refuses to change from 2nd gear. Stop, switch off and take the key out and all is fine. Yesterday, for the first time it would not change into top gear. Again, stop, switch off and all is fine.
My mercedes specialist diagnoses the problem as requring a new torque converter but also includes in the 'worst case' quote a valve body. Says that it is a waste of money to replace the ATF as the problem has gone beyond that (the car has never had a fluid or filter change).
My concern is .... if it was torgue converter, why is it sometimes just fine. The quote seems as though they are still not sure ..... sort of ... lets fit a torque converter and if that does not sort the problem then it must be the valve body. Why would someone include a valve body in the quote if they believed it to be the torque converter.
Why do the computer faults not show up the real fault?
The estimate for this repair is over £2K - how do I get a realiable second opinion? Any help/suggestions greatly appreciated.
