Cant see the fog. They move amongst us.
Sigh...
Sigh...
I've got ILS but during the fog the rear fog light didn't come on, it was fairly dense, so was wondering how dense it actually has to be to come on automatically?
Yes and the drive home tonight in heavy rain found about 8 drivers with fog lights on in the rain,I suppose they were a very small percentage in the hundreds of cars I encountered ,I always wonder if those eight have ever stopped to think why the rest of us do not put our fog lights on in the rain.
I only put mine on when I'm struggling to see the car in front. - I figure that if I don't need their light to see them, then I don't need mine on for other drivers to see me.
The lights are there for any conditions that severely limit visibility, not just fog.
Very heavy rain /spray, smoke from roadside fires etc could all be legitimate uses.
Wrong. Have you thought about the effect of rear fog lights have on the driver behind when mixed with spray? Quite apart from the fact that it means it gets confused with brake lights, the glare is really distracting. Fog lights are for, umm FOG!
Wrong!
From the UK Highway Code ... No mention of use only in fog
"Rule 226
You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves"
When does spray cause you to not be able to see anything for more than 100metres? Never seen it happen at all. You can see people's normal tail lights even in thick spray. Using fog lights in this situation is both counterproductive and potentially dangerous as you cannot see brake lights easily.
So many people over think these things.
A fog light on the right of the car will make it difficult to see brake lights? Plleeaaasssseeeee.
Everyone wants to be offended...red lights don't dazzle...look at one for a long time, look away...do you still see it...no.
