SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
hi
at the weekend i fitted the aux loom to comand (thru glovebox to back of comand).
i connected a MP3 CD walkman player to this and seems to work ok, apart from you get some interferance (ie you can here the cd mechanism a bit). Also the volume seems to be quite low compared to the radio.
i think i got the pins correct on the back of comand but the instructions i had didnt say what pins the black wire and the unshielded wire should go to, instead just referred to them both as black thick and thin wires, but i dont know if i got them the correct way round.
if i didnt would that cause the problem above? just want to avoid pulling comand out again if this all sounds normal.
does anyone else get interference with the aux loom at all?
cheers
p.s. they should put the pop-out hole in the glovebox on the right hand side of the box
cheers
