Auxilary heater C220 CDI
ziggy
Wolves, UK
C220 CDI SPORT
Does anyone know of/ or is aware of problems of failure of Auxilary heater. This is the heater that's supposed to warm engin coolant if its below 8 degrees C, found under the front drivers side wing.
The previous owner said you are supposed to hear it when it kicks in! I definetly can't hear anything.
Any ideas anyone?
Cheers
Richard W
Berkshire
BMWs :-)
Mine can be heard very faintly just after the engine is switched off, it sounds like a slight whistling noise (jet engine - ish?).
Don't forget when the switch is red the heater is off.
I've found it does warm the interior of the car much faster when switched on.
HTH
R
OP
OP
Z
ziggy
Wolves, UK
C220 CDI SPORT
Thanks for response. How much quicker? Still takes heater 5-10 to warm up first thing on these cold mornings. Is that normal?
Richard W
Berkshire
BMWs :-)
Yes - the car certainly doesn't feel warm for at least 3-4 minutes, and then takes a little while longer to warm through completely. I do have an estate though and don't keep the load cover closed.
R
OP
OP
Z
ziggy
Wolves, UK
C220 CDI SPORT
Many thanks for that Rich, I can sleep well now I've aquired my new MB electronically heated thermals that glow in the night, good old German realiability!
Zen
