Nigel44
Hi
Can someone help.
where is the Auxiliary Battery located on my 2012 S Class 350 blue tec
Can someone help.
Thanks Atavus - much appreciatedI’m sure I mentioned the Rescue Assist QR code in the other thread.
I scanned mine just now , its on the passenger side pillar. Worked a treat.I’m sure I mentioned the Rescue Assist QR code in the other thread.
No mines a 2017 c207 / e350 bluetec.Thanks for the reply - I will check tomorrow is yours an S Class CDI blue tec what year buddy, mines 2012?
My question now is do I change it, although its seems ok - I am not sue what the crank reading is as cant test this. what the verdict guys?View attachment 105102This is behind the back seat tested it on the meter is charging at 14.3 and reads 12.7 engine off - looks ok
Have you tried charging the aux battery with a battery charger?My question now is do I change it, although its seems ok - I am not sue what the crank reading is as cant test this. what the verdict guys?
Thanks - problem solved, I had a dead cell in the batteryHave you tried charging the aux battery with a battery charger?
