Nigel44
Hi
Can someone help.
where is the Auxiliary Battery located on my 2012 S Class 350 blue tec ?
Can someone help.
Thanks I will check it out - much appreciatedIn the boot possibly , right hand side under a black plastic surround.
That’s is no code there only the tyre pressures ?Did you try the QR code?
Just checked the passenger side footwell behind the large plate, only wires there, and behind the drivers side dash, not there either ?That’s is no code there only the tyre pressures ?
I will in the foot well ?Try B pillars.
again; we don't know which aux battery you are referrig to. Your car may have two actual batteries; consume battery, and star/stop battery. Then your car may have so called aux battery which is backup volateg source for electric gear selector, avtually it is pack of condensators.
