1999 C-Class Petrol.
Has anybody had my problem with there C-Class the Auxiliary Drive Belt Damper is very noisy when people have listened to it they said timing chain rattle including the garage that serviced it last.
I found it by sheer luck but if I push against it the noise goes completely so removed it and there is plenty of compression on it so I don't think it is worn out, there is a bit of play where the top securing bolt connects to the thermostat housing there is a bush goes into the housing and the bolt then goes through to secure it.
