DemetrisNic
Yes, you are right. MB is very proud of these two piece discs, but the truth is that they are easily damaged, as they require special handling. This is why I am asking, if anyone has any experience with the Brembo solution for W205 amg, which are drilled, but single piece.OK a little further digging brought up the subject of hybrid disc rotors where the centre section is pressed steel or aluminium and the frictional surface disc is cast iron. These are to be found on the latest W205 and w213 models. These are evidently very easy distorted by rough handling in transit/storage when new or in use- the use of compressed air guns on wheel bolts is highly discouraged for example
some links
warped brake rotor? 2 times since Aug 2015! - MBWorld.org Forums
OneDrive
This is another possible problem?
