Flyer
Spent Sunday with the wheels off giving them a good clean and painting the brake calipers (well, only got two done
). I realised I should really be using axle stands and not the emergency jack, especially as I needed to rotate the rear wheels.
So, where from? I'm not a mechanic and this will be for occasional use, so don't need the best (or even second-best). Halfords do a pair of axle stands for £10 and a trolley jack for £22. Now, some Halfords gear is pretty good; their tool range particularly, but how does this equipment rate?
If not Halfords, where else should I look?
BTW: anyone ever painted the brake disc... the part where the wheel mounts to, extending to the actual face of the disc (the mounting bell??)? Mine are all rusty which, despite a vigorous application of a wire brush, hasn't improved their appearance much. Does VHT paint need to be applied here or is something like Hammerite Smooth suitable?
