Hi everyone,
I'm coming to you cap in hand for any advice, and help, you could give me, regarding an ongoing issue I have with my '94 S124 E280.
I recently inherited this car from my father, who had owned it for over 10 years.
When it came to me, it had a hideous misfire, which it had been suffering from for months, to my knowledge...
A compression test suggested an issue with the head. I have recently been laid off, and with what the cars current (lack of) worth, I elected to do the work myself (not realising the can of worms I was opening!).
With the head removed, the issue was obvious, a big chunk out of one of the exhaust valves. I had this changed, and the head machined, and stem seals renewed.
With the engine back together, it wouldn't start at all...I think you know what's coming...the loom was a tangle of bare wire, and dust...
I took this off, and using new wire, and Merc's repair kits for the coil leads, spliced in repair sections, put it back, and all seemed good...
However, I seem to have some legacy issues of a very heavy thirst, and a slight hesitation, and backfire, or splutter, on partial throttle, below about 2000 rpm....but fine above that figure. Oh, and gearchanges are a bit too 'jolty'.
I got the codes from the ECU, indicating MAF, coolant sensor, and fuel mix too rich. I changed the MAF, and coolant sensor, but no change...
Could the loom still be behind any of this? Or could it (hopefully) be something that won't cost a grand to replace (I think Mercedes are out of order for not putting their hands up to the fault with these looms, mine was damn right dangerous, I'm surprised it hadn't caused an underbonnet fire!) You guys seem to know about everything that can go wrong with these cars, so I'm hoping you can help, as I want to keep the car on the road, but can't really afford to keep changing parts on spec, which don't fix the issue...(nor can I really go on with 12-20 to the gallon...)
Many thanks
Simon
Many thanks
Simon
