Badge and exterior trim removal
WOODYTHEWISE
E AYRSHIRE
E 500 Coupe.
I read earlier about someone who was having trouble removing part of a broken badge without damaging the paintwork. I use a length of fishing line, it slides under the trim/badge and cuts through the 'sticky pad' somewhat similar to a cheese cutter. Adding a little WD40 to the line helps. For a tougher job I use a plastic washing peg, most of these are wedge shaped at the end.
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
Will have to try these methods. My method is to use dental floss, works a treat, takes no time at all.
I did the same thing to remove the badges from my car and as a bonus it left the bootlid smelling minty-fresh! ;)
BTB 500
MB Club Veteran
Berkshire
R129 SL500, W639 Vito 120, S203 C230
Dental floss (pref. unwaxed) works better than fishing line as it has a rougher surface so 'saws' better.
OP
OP
WOODYTHEWISE
WOODYTHEWISE
E AYRSHIRE
E 500 Coupe.
Hi Bill, good thinking, thank you, I will give it a go.
w124nut
Somerset
Mercedes W124 E320 cabriolet
On my W124, the central three pointed star on the boot lid has 3 lugs that press fit into holes. The designation E320 is stuck on and can be removed as stated above but I would recommend additionally, careful use of a hair dryer to soften the glue.
OP
OP
WOODYTHEWISE
WOODYTHEWISE
E AYRSHIRE
E 500 Coupe.
Hi, Yet another good tip, thank you, Perhaps we should have 'A Tip Of THE DAY'
Alps
London\Essex
E55 2004 Silver, E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
"sometimes" after softening the adhesive with some heat the badge peels off fairly cleanly
Troon
Staffordshire
A big one
I removed the E220 CDI from the back of my S211 using a credit card (well, a card of the same dimensions and material that I didn't care about damaging).
I "aimed" it at the thin points - the tines of the E, for example - to maximize the pressure at the contact point, and pushed, keeping the whole card as close to the car as possible to avoid pushing into the paint.
This tore the foam adhesive and removed the badges. The remaining sticky bits were dispatched with hot soapy water and fingernails, followed by a good wash down then some clay and Autoglym SRP to finish. Can't tell they were ever there now.
