Hi all,
apologies for what could be the vagueness of this message but maybe looking for some direction before spending any unnecessary money.
I picked up my W208 with some wider than necessary wheels, which meant the previous owner had 15mm spacers on them. Turning corners and handling was a nightmare. So i found on this forum a set of 18" monoblocks which i picked up and swapped the tyres over to and put on (without any spacers or modifications needed).
However, this is where the challenge is. The tyres were put on by a reputable firm and balanced. On the way home, 55mph+ the steering wobbles and it seems i can feel it through the seat too. This subsides at 72mph+ (on a private road). this isn't a violent shake and i don't feel its making the handling difficult, but its enough to feel and you know it shouldn't be there - it would get tiresome on a long journey.
I went back the following week to have the balance checked - maybe something fell off as driving out the garage etc. Got them re-balanced (they were slightly off but garage mentioned not off enough to cause the shaking) but the same issue exists - though it could be a little less harsh now (but that could also be a placebo effect). I should add, the hubs look clean enough and there's no rust etc. built up there.
Now, here's the question(s):
appreciate anyone who read this horrendously long post and any advice possible.
thank you
Naz
- As far as i know (and i'm new to Mercs), the wobbling is generally down to balancing. So, do i try somewhere else to see if the balancing is correct?
- With the previous owner having the spacers and wrong offset wheels, could the shaking actually be alignment, so i should go and see Wheels in Motion (or similar) for a full geometry setup?
- I actually have two different tyres on one of the axles, but they were fine with the other wheels, no shaking. Therefore i've practically ruled this scenario out
- Wobbly alloy - though the fitter didn't say anything when fitting and balancing?
- Something else in the suspension worth checking - but considering it happened immediately after changing the wheels i would think not?
thank you
Naz
