Smithy860
Morning all,
I’ve noticed some clunking for a while now on my front passenger side . I jacked it up this morning and got some play left to right. I took the wheel off and could feel it when I moved the disc in same direction.
Upon further inspection the ball joint has some movement and recreates the knocking sound.
The ball joint is riveted to the arm, do I grind them off and replace the joint or replace the entire arm? ( the other bushes look fine, no damage to boots)
Thanks all
Thanks all
