emailthebrowns@
My error message "dipped beam right" went away 2 days ago was replaced with "no malfunctions" and light started working again.
However got myself a small tool kit together and removed bottom plastic engine cover as suggested by Kuazizul. access no problem this way. Removed ballast unit cleaned terminal connections and reassembled.
Every thing still OK.
The light has now gone out again!
My question is if the ballast unit was on its way out would it be a bit hit and miss for a while before giving up all together or would it just fail, should i be looking for another fault?
