Dave Bailey
Here is the latest bit of "character" my car has developed...... Last evening, the BAS/ASR warning light came on. This has happened once before & on the last occasion it reset itself the next time I turned the ignition on. However, this time the light refuses to go out. I had a quick look in the user guide and noted that BAS will be deactivated if the battery voltage drops below 10v. I checked this and the battery gives a good 12.5v in static conditions, ie with engine off. ABS still works ok. BAS doesn't though, I needed to apply a lot more pressure to the brake pedal to get the ABS to kick in than would normally be the required. Cruise control doesn't work either, though the speed limiter does. I have not been able to check if ASR works at this stage. Before I embark on another exbenzive trip to the stealership, can anyone please offer a pointer as to what the problem might be and if it is something I can sort out myself? It would be good if this can be sorted out quickly and easily. The car is a 1998 C280 Elegance (V6). Thanks in anticipation.
Dave
Dave
