Bas asr
andypandy
Suffolk, England
mercedes e200 '97
I've got an intermittent fault on my w210, the BAS ASR lights come on intermittently when I go above 65mph, I've read up about it but most others were not intermittent, they remained on all the time. The lights go out if I turn the car off and on again. Is it likely to be a brake on off switch? That seems to be what the others were.
Brake light switch is a well known culprit for causing this issue. After that you could be looking at the BAS control module or the BAS brake master cylinder sensor.
If it's speed-related it could be an incorrect wheel/tyre size issue.
