gbjeppm
- Oct 31, 2006
- Location
- Surrey
- C207 E Coupe 350cdi, W166 ML 250 Cdi Sport, R171 SLK 350, Suzuki V Strom DL650
Hi All,
I am installing a parrot ck3100 into my W208 post facelift with Audio10.
I have plugged the supplied cabling in and the stereo works OK, no power to the Parrot, I suppose as the power is supplied via the canbus to the Audio 10.
So I need to tap a 12v ignition feed somewhere, I initially thought of the courtesy light off the glove box, and have taken a photo of it below. I will actually use the cigar lighter as its closer but the wiring is the same.
There are 2 wires going in Brown and Green/Pink. So I dont blow any fuses can somebody tell me which one is the ignition feed?
