- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
As per the title: We need to replace a bathroom suite in one of our rental properties as well as some other changes
It is a mid-terrace Victorian house (1880) with a bathroom that was moved upstairs at some point when an extension was added, we think around 1940.
The extension (at the rear of the property that includes the kitchen below) is not well insulated and we will look at addressing this via exterior rendered cladding if possible (it is in a Conservation area) or internal insulation board. Any experiences of this welcomed.
We will also be replacing the bath, shower (currently 9.0Kw electric fed from a 6mm cable about 9 m long), sink and lavatory. Now madam would like a higher flow shower and integrated sink / lavatory unit (Cloakroom style?) but I am open on this as I have not found any that seem designed for full bathrooms.
I am also very keen to put in electric underfloor heating (the room is approx 2.7m x 2.4m)as the single towel radiator (1200mm) struggles to keep the room warm in cold weather and insulation alone may not be enough.
So any recommendations for bathroom suppliers, insulation type, underfloor heating suppliers etc and, can a Combi boiler be used with a boost pump for a shower?
Thanks in advance.
Thanks in advance.
