Battery breather pipe, 210 Estate
Discussion in 'Electronics' started by Smarties, Oct 24, 2011.
  1. Smarties
    Smarties Active Member
    444
    Oct 14, 2008
    Just replaced the battery on my trusty (or is that rusty) E240 estate (210 series), and have noticed that there is no breather pipe on the battery. Battery is located under the rear seat and there would appear to be a hole for it to go out off in the floor. Should it have one, if so, where can I obtain it. Thanks for looking
  2. GordonTarling
    GordonTarling MB Enthusiast
    1,678
    Jun 29, 2004
    Grantham
    Car:
    2007 E63 AMG V8 Estate
    Yes, there should be a pipe. Best bet is to get one from your dealer or, maybe, a scrapyard.
  3. Ted
    Ted MB Enthusiast
    5,758
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Ideally you should have a battery breather pipe.
    However these days voltage regulation is much better than it used to be, batteries are better designed, and there will be little chance of gas produced, and even less chance of acid mist.
    The exception to that would be if your regulator failed and your car started overcharging.
    Personally as it's an older car, I would leave it until I was next in Halfords, and get some washer tubing which should do the trick.
  4. OP
    OP
    Smarties
    444
    Oct 14, 2008
    Thanks chaps, I will look out for one
  5. welland99
    welland99 Active Member
    694
    Feb 26, 2009
    Malvern
    Car:
    W210 E280 estate 1999 facelift; 6th gen honda accord coupe 2000
    My 210 estate has a battery breather tube going through the floor, but the top end of the tube isn't connected to anything. The battery itself doesn't have a place to connect it to.
    Is the tube meant to be venting the space around the battery?
    Or
    Do some batteries have a vent point, to which the tube should be attached?
  6. Dec
    Dec MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
    The battery vent hole may be ot the end or side of battery and concealed behind a blanking cover.
    Does your vent tube have a 90 degree plug so as to plug the tub into the battery?
    Dec
    [​IMG]
    [​IMG]
  7. welland99
    694
    Feb 26, 2009
    Malvern
    Car:
    Hi Dec,
    Thanks for your detailed reply.
    My tube does not have an elbow on the end and i cannot see a hole in the battery. That does not mean that the battery does not have a vent, because it may be hidden on the far side of the battery where I can't see.
  8. Dec
    Dec MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
Share This Page
