How far is "the shops" ?
My W204 stood for a week until yesterday and it started fine. I drove "round the block", 30 - 40 mph, for 15 minutes.
I expect the charge to last for another week.
Rather doubt it, and I found out the hard way that MB's can be finiky about battery voltage - about 3 weeks ago wife wanted to drive to the surgery, all seemed normal (opening doors etc) until she tried to start the car, no reaction at all to Pos. 3 with the key. Battery condition tester said battery 50% charged.
Do you have power available where your car is parked? If so I'd get a battery conditioner and have that connected while the car is parked up. Lidl/Aldi do cheap ones, there's one on Amazon https://www.amazon.co.uk/dp/B009A83P1E/?tag=amazon0e9db-21
or the most popular more expensive choice is CTEK.
Then you are taking more out of the battery than you are putting in.2miles return
I think you should charge the battery. I'm doing something similar with a 7 mile round trip once a week. I charge the battery and it takes 1 - 2 hours to get back to full charge.
If you start a journey with a fully charged battery and the engines starts instantly then the 2 miles is more than enough to put back what the starter takes out. Last time I did the calculations it came out at a few hundred yards
The starter isn't the issue but there are several other factors:-
Unless you use a lot of revs the car will most likely not have finished the previous journey with a 100 % fully charged battery because the smart alternator won't allow it to.
Every time you open a door the car wakes up and pulls something like 8 amps from the battery for several minutes so if you access the car between journeys that won't help.
The alarm current is small but it adds up over 168 hours in a week. I only have accurate figures for my old car which drew 5.7 amp hours per week. Newer cars may be less but it's no surprise that it can need up to 2 hours on the charger.
Try it. Put a charger on your battery and see how long it takes to reach full charge.
Do you charge once a week ?
Serious question for those who have fitted a permanent connector and leave it charging.
Have you any failsafe system to prevent driving off with it still connected?
My battery is under the driver's feet, so the charger is [almost] blocking the pedals ...Serious question for those who have fitted a permanent connector and leave it charging.
