Dickster
Hi there,
I have owned my car for 15 months and this warning has always appeared when I start the car. It does not reappear whilst driving so I have lived with it.
I fitted the relay 57 initially but that hasn’t sorted the issue - although that and terminal 61 are mentioned when I run a scan for fault codes.
The car is on trickle charge all the time. A couple of days ago I disconnected the charger and let the car sit for 24 hours. When I check ed the voltage both batteries were 12.7v. I started the engine and both batteries indicated 14+ v. So everything seems to be in order.
The roof is sluggish sometimes - sometimes it goes up and down in 20 secs, sometimes is reluctant to move at all. I put it down to a weak battery but now not so sure.
Why does the warning keep appearing?
