Tezz
Ok so hear we go again.
So back in April I had a battery drain, it was found to be rear tail gate handle, new battery fitted by RAC and handle fixed since then no issues with battery, start fine all ok
Used car few days before all fine apart from the Command 20 was turning its self of and on, after a few times it came on and all was fine, used yesterday all was fine. when I got car this unit was disconnected apart from radio, I reconnected all wires ect and been fine since
only thing iv never done before, was about 2 hours later realized I left some thing in car, opened it up, got what I needed and locked again, usually never open with out starting car, this morning car dead to point door locks don't work. opened with key everything dead, no alarm flashing light, no ignition nothing. checked all switch everything off ect.
Points maybe unrelated
So how do I remove the battery to charge so alarm dose not go off ? bearing in mind its totally dead
Is the alarm siren near pollen filter or under a wheel arch?
Any idea how long the alarm will go off on its internal batteries ?
What do you think is the likelihood of the command unit being faulty and getting stuck in a wake up loop of sorts
It only recently did a 180 mile round trip so would think battery would be charged ok and I use it every few days for about 20 miles
I do have an Icarsoft, very recently I plugged in just to check every system 1 at a time to check for any faults and found none.
what ever the drain is was enough to drain battery overnight
Any thoughts
Tezz
Any thoughts
Tezz
