Hi guys not sure if I'm on the right page as I'm new to this . I have a 2004 c180k coupe and I've got 2 issues with it , I had a battery drain on the car replaced the battery twice and still kept draining i then started look for what could be the cause of the drain finally finding fuse 9 was the problem i pulled the fuse and the problem has stopped , the thing is fuse 9 controls a number of things and I need your help to determine what it is causing battery drain. Issue number 2 is about 3 days ago a fault came up on the display say display faulty visit workshop but everything is still working as it should , how do I get ride of that fault . Thank you
