Joderest
Hi All
Not going to bother you all with the issues with my ML270, as documented to death on other threads. I cannot have anyone look at the car for a few weeks due to my work and their workload, so, against my better judgement i am going to try and do a leak/drain test on the battery, and need a bit of help.
I have a small digital meter, it has a 10amp setting, if i disconnect the negative pole of the battery, connect black side of meter to the battery pole and the red side to the battery lead, will this give me the amps reading i require ? (meter set to 10amp setting)
What am i looking for as unacceptable, and what is acceptable. I have already done voltage, seems to drop to 12.4 volts overnight, its a new Yuasa battery only fitted this week. Engine starts really well.
Any advice ?
Any advice ?
