I have a 1998 C180 W202 Petrol. Last April I replaced the old battery. The new one only lasted to January, I got a replacement, but this went flat a few weeks ago. I put a bulb tester on the neutral and the light stayed on. I took each fuse out individually and tested each time, the light stayed on. I took all the fuses out at the same time and the light went out. I put them in one at a time tested and removed them. The fault seems to be with fuses 10 and 30. I put all the fuses back except these two and the light was on showing a fault. Where could the drain or short be coming from?
