television
Hardcore MB Enthusiast
BTB 500 said:However you can buy a 0.1A resolution clamp meter for £55, which would be fine for this job since we're looking for a drain of around 1.5A.
A drain of 1.5 amps is not very usual and fairly easy to find without a meter.
When the fault is in Can Bus 4 (Command) the drain is around 150m/a in the wake up/shut down mode, a resolution of 100m/a is of no use, the same goes for alarm systems.
A multimeter costing £5 is of much more use than a Clamp meter, and you can go down to a couple of m/a.
malcolm
