DITTRICH
I had parked up, turned the engine and a/c off, and was listening to the radio for about 40 minutes.
Wife turns up, gets in, and I fire up the engine (radio still on) and move off.
After 10 seconds of getting out of the carpark, the dreaded amber battery stop message above appears. I pull over, engage park with engine running, and wait 10 minutes. Message does not go away.
Points to note:-
1 It isn't possible to rid of the message - eg to transfer to the trip display and watch the alternator engaging and charging the battery.
2 I reason that since the car works and the car believes the battery is charging it should be possible to complete the 20 mile journey back home'
3 I complete the journey back home, keeping an eye on the engine temperature to make sure the poly v belt is OK. I checked later and it was fine.
4 I used eco mode and made sure all the consumers were off during the journey.
5 Eco mode gear changes seemed to be very smooth and the activation/deactivation of "D" was less frequent and totally smooth.
6 On arrival in the underground parking, after checking the poly V belt, I switched off, waited 30 seconds and switched on again.
7 Fault cleared, car appeared normal. switched off again after 2 minutes.
Hypothesis: starting the car on a 6 year old battery with the radio on etc, dragged down the voltage sufficiently to trigger the warning. Once the voltage was down, the message got "stuck". After driving back, switching off/on it righted itself i.e. the alternator WAS charging, so maybe the car knows this for real, not just believing its OK.
To be honest I sort of reasoned that the battery was at fault, but did not want to turn off the battery in case the car would not start again.
Moral: If the car says battery low: stop and charge, check how the car behaves, and if OK, carefully drive home with all consumers off.
Cars these days try to be too clever, and are economical with the truth on the display panel
Points to note:-
