Becker map pilot
Rosswil
Peterborough
C-class and A-class
Hi new here and to Mercedes just purchased a C 220 and an A 150 for myself and the wife. Mine came with the Becker unit in but my wifes did not. I have purchased a unit second hand and when installed in the car I get a message asking for a code the previous owner says they didn't serve code. Is there anyway to get this code removed/unlocked at all. Thanks for any help/ advice.
The Becker unit is basically just a glorified SD card. So even if it doesn't work you can wipe and start afresh. I had a lot of back and forth with Becker tech support but basically they were not willing to help at all. I ended up buying the latest maps off a well known auction site and its be great since.
Up to you which route you take of course but I found my solution by far the easiest and cheapest! When i works its a great system I find. Not as good as google maps but pretty good.
