Hello,
For the last few months I have been having some minor, but irritating problems with my Becker sat nav:
* Map slow to change - you've passed a road before it shows on the map
* (Linked to above) Turn instructions spoken after you've passed the turning
* Satellite detection fails completely
* Becker doesn't start when you turn on the engine, instead it 're-initialises'. (normally, you turn on the engine and the sat nav menus shows pretty quickly. When I get the problem, it comes up with the 'Becker' home page, or says 'Navigation module reinitialising', and takes ages to boot up).
The car has been in to the garage a couple of times, and they could not find anything wrong. After the second time, they replaced the Becker unit. Sat nav appears to be OK at the moment, but I haven't used it for a long journey yet.
Gearbox problems:
Last week, I was driving along and everything seemed OK on country roads, but when I got onto the motorway, I could not change gear at all (auto or manually) and the engine seemed to be detatched from the gearbox, in that the revs would increase but the speed would stay the same. Also on over-run, instead of the engine revs slowing with your speed, as soon as I took my foot off the throttle, the revs dropped back by 500 RPM. These problems all cleared after an engine switch-off/switch-on.
The garage said it was an ECU fault, so they reset it and updated the software. All OK so far.
Today, I switched on and the sat nav didn't start up at all - I had to pop the unit out and pop it back in again.
I know that the sat nav problem is not a major thing (until you really need it!), but it is very frustrating. Has anybody got any thoughts on these problems, and do you think there is a chance that the problems might be related?
Thanks for reading this far.
Nick
Gearbox problems:
Nick
