Belt Change on E300TD
bill_mill_65
Midlands
1999 E-Class T Avantgarde, ST Fiesta
I'm going to change the drive belt on the E Class (OM606 engine), because I know it will wait until February when it's dark, and the rain is horizontal before it decides to part.....What I'd like to know is if the bolt that I'll have the scafolding pole attached to is a regular or left handed. Can someone learned inform me please?
Thanks in anticipation!
230K
Belfast
09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
Hi
What are you trying to do???
If you are changing the drive belt (fan belt) you just slacken the 13mm nut on the head of the bolt that holds the spring tensioner, take up the tension with a socket set extension bar, withdraw the bolt and release the tension on the spring tensioner and hey presto the belt is slack enough to remove.
Hope this helps
230K
OP
OP
B
bill_mill_65
Midlands
OK thanks for the reply. I'm just changing the belt, but thought I had to take off the fan to be able to access everything sufficiently. So that's not the case then?
My question was asking, if the bolt that holds the viscous coupling to the water pump is conventional or does it have a left handed thread?
230K
Belfast
Hi
The Allen headed single bolt that holds on the viscous fan is conventionally threaded. Anti clockwise to remove the bolt.
You do not need to remove the fan to change the belt.
230K
OP
OP
B
bill_mill_65
Midlands
OK thanks for the info !
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
i'd 2nd everything 230K says here.
also take a photo or draw a diagram of the layout of the belt and pullys before you remove so you know how to refit the new one
