Parrot of Doom
Driving home today, just a couple of miles, accompanied by the most awful belt squeal you can imagine. Nursed her home and lifted the bonnet to find that the large sheathed spring on the belt tensioner assembly has snapped clean in two, and is dangling from the engine
So, because its raining outside I can't check, but is it quite easy to get the spring back on its bottom mount? Is is a hook, or an eyelet? The lower half of the existing spring has gone bye-byes somewhere.
Something else I noticed was the metal box at the front of the engine, nearside, that appears to be something to do with the braking system - its got lots of metal pipes entering/leaving the top of the box. Its on rubber pads and one of the pads is missing. Is this just a case of lifting it up and inserting a new pad, or is there more to it?
