What belt wrap kits are available? Are they a necessity? I do not know if I get belt slip, I do not know what it would be like even if I was getting it.
Belt wrap kit as the name suggests is designed to prevent belt slippage. I'd just get the right belt length instead. Especially if you don't know if you belt slips.
I guess it probably doesn't, as it's been like it for a while with the current set up. I'm taking it to MSL on the 12th August for a check up so if there are any belt issues they will be able to tell me!
I have the 77mm pulley & Headers done at Msl, with no Bwk. Acid is not a fan, or at least he certainly wasn't previously. My 77mm pulley has been good as gold without one for ages. Think it is the Americans that are bigger fans of the Bwk than us, on average.
You're a brave man driving tonight with no ESP..needed a boat in my part of Bucks..are you sure you're getting belt slip coming off the throttle?
I wouldn't rush into a belt kit..your car is going to the best possible place at MSL..Acid and his guys will check it out and advise accordingly..if he's not a fan you can bet your life there's a good reason..
I turned it back on after that LOL. It was just to see how it would react from stationary. It was a sharp let off of the throttle so I suspect that the s/c couldn't slow down with the instant drop of rev's.
This was in Aylesbury, rain back from Chesham wasn't too bad tbh.
