BaldGuy
Got home tonight after the car being a total **** all day, Coughing and spluttering etc etc... So i decide to disconnect the battery overnight to give the computer a reset and anything else that might reset itself..
Shut the boot and thought all was well, I chickened out as I thought that the car would not be alarmed etc overnight, so I went to open the boot and it wouldn't open!! Starting to panic now as all of the doors are open.
I called the Benz 24 hour support for help and waited for a call back. It took me an age to get in, as the lock was semi-seized due to non-use. Finally it opened and I reconnected the battery.
The engineer from 24hr support calls back and I tell him I'm in and sorry for the waste of his time however he said that my troubles were not over.
Upon starting the car the ABS and BAS/ESP light stays on...
To fix this he says turn the steering full lock to the left and then full lock to the right and then back to the centre...This cured the lights!!!!
Next up was the question "Do you have all round electric windows"?
"Yes"
"Well the one touch operation won't work anymore on all of them"
To fix this and you will have to do it to each window, Hold the button down on the first button click until the window is fully open, The window will not open on the full button depress or close for that matter!!!
Now do the window up on the first button click and when it reach's the top hold the button down on the first click for a further 5 secs. After 5 secs release and all is fixed!!
Apparently there is a similar fix for the powered sunroof...
I had to share this with you guys as I'm sure this will catch people out when working on hifi/alarms etc
"Yes"
