Sweet Moses, that's some list!I have had the car since December 2015, third owner from new MY 2006, 2005 Registered, bought with 69k miles, now has 102k miles on it.
It had MB History but was missing two services and had been serviced by Merc-Care.
I bought it and despite not requiring a service yet, I took it to PCS for a thorough check over and service, and has been serviced by PCS ever since.
I know somethings would be classed as reasonable to expect to have to replace/repair in the time frame I have had it, and some items possibly could have been left but I like things 110% correct, I dare say I have forgotten something.
Below is a list of parts issues I have had to address since buying it
All four front ball joints.
Engine mounts.
Gearbox Mount.
Charge Cooler Pump.
Both Front Airmatic Struts (failed at different times over approx three years).
Suspension Air Compressor (twice at different times).
Airmatic Relay (twice at different times).
SBC Pump.
Front Discs/Pads.
Rear Discs Pads.
Engine Water Pump.
Serpentine Belt.
Charger Belt (Twice).
Header Tank.
Rear Main Oil Seal.
Oil seals in the Oil filter housing for the Water/Oil Cooler.
Supercharger (Complete).
Supercharger Pulley.
Numerous engine pulleys.
Charger Belt Tensioner
Serpentine Belt Tensioner
Propshaft Rubber doughnut.
Secondary Air Injection Pump.
Air Valve (something to do with the Secondary Air Injection.
Gearbox Rebuild.
TV Tuner.
Rocker Cover Gasket replacement.
Spark Plug replacement (has been carried out twice now once when I bought it and second time in the first lockdown carried out by myself).
Spark plug leads.
Drivers side electric window switch pack.
Drivers side door window regulator.
Engine Cover (Due to the badge being missing).
One Fog Light.
Front Battery (Twice).
Rear Battery (Twice).
All eight electrical connector bodies for the Coil Packs.
