A lot depends on aerodynamics - trucks/vans/SUVs etc. have a lot of drag so you save significantly more fuel by driving slower. Cars less so (apart from convertibles with the top down).
Hey people
what motorway speeds do you find your car at its best MPG (state what mercedes too)
I cant drive at 60mph its just too slow
C Class Coupe 220 CDI 7G
at 72 mph i get around 54 mpg
I think lorries cruise at 56...because they can't go faster.
Tec is right, Lorries cruise at 56 for similar reasons. It's the most speed you can attain before the air gets too thick and the extra distance you cover is disproportional to the drag created.
Over many years of driving I've found ther biggest improvement you can make to the average MPG on any trip (particularly motorway) is to avoid accellerating up hills. Let the car slow down a bit, who cares?
Downhill, you can use surprising amounts of loud pedal without too much impact on your overall MPG. Do it uphill, and it drops lika a stone.
Exactly. This is why cruise control hurts your MPG sometimes. As it'll maintain your speed no matter what, so accelerating up hills and braking on downwards slopes!
Again it's not that simple. Basically you're trying to minimise energy use and if you manage to coast perfectly then you eventually end up with the same or greater speed going down the other side as you started with going up.You're right if you can let the car slowly loose speed, then gently raise it back up again is best for mpg. If you're going down hill, you can completely lift off and roll freely, and watch your mpg climb rapidly the longer you can free roll.
