I'll ask my brother for you - he's had a set fitted recently and is very happy (and very fussy).
He did a lot of research first.
I bought a pair from Howdens, for my ensuite, they are basically cupboard doors designed to open and close from outside the cupboard, I modified mine by removing the middle hinge pin and replacing it with a handle formed from a wire coat hanger, this enables the doors to be opened and closed from the inside as well as the outside, the wire handle folds flat inside allowing the doors to fold flat against them selves when left open, so I can easilly access the ensuite from the bedroom, I also fitted a small brass knob centrally on the outside. If they are just for a cupbored then these are pretty good. I hope this might be of use. Eddie
