Bilstein Shocks and Kits - Reduced To Clear
EuroCarParts
Wembley, London
European
Hi Guys
As you probably know we are the UK importer for Bilstein Suspension - However even we come across some parts which are slow movers, and need to have a 'Spring Clean'
The below parts are WIGIG - When Its Gone Its Gone! - They are reduced to clear and are on a first come first serve basis!
If you want to order or enquire about these, please phone 0208 956 5175 and ask for IRFAN,
Below is a small selection - We current have 19 different Mercedes sets which we want to clear - If you want to enquire about a different application - let me know, and ill have a look
Part Number: 938226170 (99-081775)
Description: BILSTEIN B12 SUSPENSION KIT MERCEDES E CLASS W210 SALOON
Type: 4 x B8 Shock Absorbers & 4 x lowering Springs
Application:
E240 00-02 [125kW]
E280, 300D, 320, 420 95-97 [without self levelling]
E280, 290TD, 300TD, 320, 430 96-99 [without self levelling]
Lowers: 35mm F&R
RRP: £567.50
CLEARANCE: £408.24
Part Number: 935220170 (24-100403)
Description: BILSTEIN B6 REAR SHOCK ABSORBER MERCEDES C CLASS W202
Type: Uprated Standard Shocks
Application:
Mercedes C-CLASS (W202) C 180, C 200, C 200 CDI, C 200d, C 200 Kompressor, C 220, C 220 CDI, C 220d, C 230, C 230 Kompressor, C 240, C 250d, C 250 Turbo-D, C 280 05/93 - 05/00 55 -145 kW
Mercedes C-CLASS Estate (S202) C 180 T, C 200 T, C 200 T CDI, C 200 Td, C 200 T Kompressor, C 220 T CDI, C 220 Td, C 230 T, C 230 T Kompressor, C 240 T, C 250 T Turbo-D, C 280 T 06/96 - 03/01 55 -145 kW
Mercedes CLK (C208) 200, 200 Kompressor, 230 Kompressor, 320, 430, 55 AMG 06/97 - 06/02 100 -255 kW
Mercedes CLK Convertible (A208) 200, 200 Kompressor, 230 Kompressor, 320, 430 03/98 - 03/02 100 -205 kW
RRP: £122.39 Ea
CLEARANCE: £66.49 Ea
Part Number: 935220150 (24-068802)
Description: BILSTEIN B6 REAR SHOCK ABSORBER MERCEDES C CLASS W203
Type: Standard uprated Shocks
Application:
Mercedes C-CLASS (W203) 3.5, C 180, C 180 Kompressor, C 200 CDI, C 200 CGI Kompressor, C 200 Kompressor, C 220 CDI, C 230, C 230 Kompressor, C 240, C 270 CDI, C 280, C 320, C 320 CDI, C 350 05/00 - 75 -200 kW
Mercedes C-CLASS Coupe (CL203) C 160 Kompressor, C 180, C 180 Kompressor, C 200 CDI, C 200 CGI Kompressor, C 200 Kompressor, C 220, C 220 CDI, C 230, C 230 Kompressor, C 320, C 350 03/01 - 90 -200 kW
Mercedes C-CLASS T-Model (S203) C 180, C 180 Kompressor, C 200 CDI, C 200 CGI Kompressor, C 200 Kompressor, C 220 CDI, C 230, C 230 Kompressor, C 240, C 270 CDI, C 280, C 320, C 320 CDI, C 350 03/01 - 75 -200 kW
Mercedes CLC-CLASS CLC 160, CLC 180 Kompressor, CLC 200 CDI, CLC 200 Kompressor, CLC 220 CDI, CLC 230, CLC 350 05/08 - 90 -200 kW
Mercedes CLK (C209) 200 CGI, 200 Kompressor, 220 CDI, 240, 270 CDI, 280, 320, 320 CDI, 350, 500, 6.2, 63 AMG 06/02 - 110 -373 kW
RRP: £117.00
CLEARANCE: £61.06
Part Number: 935220040 (24-069069)
Description: BILSTEIN B6 REAR SHOCK ABSORBER MERCEDES E CLASS W211 SALOON
Application:
Mercedes E-CLASS (W211) E 200 CDI, E 200 CGI, E 200 Kompressor, E 220 CDI, E 230, E 240, E 270 CDI, E 280, E 280 CDI, E 300 BLUETEC, E 320, E 320 CDI, E 350, E 350 CGI, E 400 CDI, E 420 CDI, E200 NGT 03/02 - 75 -231 kW E 200 CDI, E 200 CGI, E 200 Kompressor, E 220 CDI, E 230, E 240, E 270 CDI, E 280, E 280 CDI, E 300 BLUETEC, E 320, E 320 CDI, E 350, E 350 CGI, E 400 CDI, E 420 CDI, E200 NGT 03/02 - 75 -231 kW
RRP: £137.40
CLEARANCE: £73.67
