Clk 320 Auto coupe 2002 51 plate elegance
Still got a few shakey moments despite changing wheels. It's hard to explain and only I seem to notice it but sometimes the car seems a little well shakey! Could this be engine mounts maybe and if so how much is diagnosis and repair.
Only warning lights are oil sensor and oil level check which I presume is a dead sensor which I will do next service.
Can also notice it a bit when held in D at lights but also at higher speeds. Can't tell exactly where its from but the new wheels and tyres are all ok and standard.
Engine temp is usually just over half way on a long drive. Used to be exactly half on the 230k.
Oil is clean and fresh, gearbox oil and filter probably never been done.
