Got a 5 yo CLK 280. All works well. Have an annoying issue with the CC. When driving and exceeding a preset speed, 120 kph in my case, a short chime sounds to indicate speed limit exceeded. At that point I cannot activate the CC. If want it activated, I have to do it while speed is below 120. So let say I have activated CC starting from 119 kph and keeping the lever up till the speed reaches 140 kph. So far all is good, no issues. However, if for some reason I have to drop down to say 130 kph (slower vehicle in front of me), it is not possible to reset the CC back to 140 kph. All CC controls, display toggles, etc. are blocked and do not respond. In order to reset back to the original 140 kph setting I have to then drop back to below 120 kph, at which point the reset function works okay. This is not only annoying but could also result in an accident if I don't pay careful attention to the situation around me. As a side note, I don't think the mentioned 120 kph speed limit has anything to do with the max speed limit that is set up and cannot be physically exceeded. Any suggestions?
