Bleedin' Jacks
Omega
West Cornwall - U.K
Anyone know how to bleed a hydraulic trolley jack please ?
Mine was only lifting half way so I topped it up with Jack Hydraulic fluid. It made it a little better, but not 100%.
I can no longer see the makers name or instructions.
Cheers
Stratman
Sunbury
W203 C200 CDI '04Estate
When I've done it in the past I've opened the lowering valve then pumped the raising lever a few times. That usually did the trick.
OP
OP
Omega
Omega
West Cornwall - U.K
Hi SM: thanks for the reply.
Tried it - it didn't work.
I think it's fixed though (famous last words).
Most people said to lower the raise-arm, open the oil filler / bleed cap & pump handle several times. I had already been doing this.
Today though - as pumping didn't seem to have the desired effect - I decided to pull the raise-arm up manually and try again. After about 3 pumps, it became very hard :)o).
Replaced the cap & lowered arm. As soon as I operated the handle now, I could tell the difference. Excuse the double-entendre but it stood up high & proud. As long as it’ll do it with more weight than me on it – should be o.k.
Hope this helps other readers.
Dieselman
Banned
Peugeot 403 Convertible
It will go soft again as the oil leaks.
OP
OP
Omega
Omega
West Cornwall - U.K
,,,, but now I know there's a self-help cure,,,,, might last for years,,,
