Bleeding 270CDI after new A612 070 31 32
ldare
Wales
2007 R320 CDI Sport / 2003 270ML CDI Inspiration
Hi
If I replace A612 070 31 32 will I need to bleed the air out afterwards?
Cheers
I'm guessing this is a fuel pipe replacement?
If your fuel filter is still full then it's probably easiest to just keep on cranking the engine over until it does fire up. This will likely take several attempts, don't just hold it cranking continuously, give the starter motor a rest every 5 seconds or so. it'll fire up eventually then leave it idling for a few minutes which will give you a chance to get back around the engine and inspect for any leaks. It may splut or cut out when you open the throttle until all the air has passed through.
When I did this on my 270 I primed the fuel pipe with fuel using an oil can prior to connecting it up. If you don't you can end up cranking the engine for ages even though it's meant to be self-bleeding.
Excellent - yes a good few turns and she started up in the end.
